cadamrao Posted April 28, 2014 Posted April 28, 2014 Hi I have a some easting,northing coordinates;from that coordinates I need to draw a polyline by using SCR methods.I'm trying to run my scr command;but showing unknown some error in command line.Please help me.I will sending dwg and scr file for correction. Thanks in Advance. venki R scr.scrFetching info... Boundary Line.dwgFetching info... Quote
steven-g Posted April 28, 2014 Posted April 28, 2014 Check your scr file, at the end of lines 4,6 & 7 you have an extra space, autocad reads this as the enter command and so creates odd results. Quote
cadamrao Posted April 28, 2014 Author Posted April 28, 2014 Hi I didn't get ;could you modify send to me please. venki Quote
dbroada Posted April 28, 2014 Posted April 28, 2014 check this out. These spaces are confussing AutoCAD. Quote
cadamrao Posted April 28, 2014 Author Posted April 28, 2014 Yaa..now its working,only something straight line;but not my drawing (boundary line). please clarify it. Thanks for spending time. Quote
ReMark Posted April 28, 2014 Posted April 28, 2014 The script will only draw what you tell it to draw. Quote
dbroada Posted April 28, 2014 Posted April 28, 2014 as ReMark says, you have given the co-ordinates almost in a straight line. Did you mean to use absolute coordinates rather than relative ones? If so, replace the @ with a # Quote
cadamrao Posted April 29, 2014 Author Posted April 29, 2014 hi I has replaced @ with a # still not in my boundary line dwg. Quote
ReMark Posted April 29, 2014 Posted April 29, 2014 Maybe if you gave us ALL the information we might be better able to assist you. Could you do that please? Otherwise this is going to get very frustrating quickly. Quote
eldon Posted April 29, 2014 Posted April 29, 2014 What happens if you remove the extra character (@ or #) from the front of the line, and just leave the figures on each line? _PLINE 22.0954,7.0898 24.4464,3.5113 30.3239,6.3703 27.7264,10.1761 31.0933,12.4671 32.6094,9.9539 36.3995,12.4066 ;end of file Quote
BIGAL Posted April 30, 2014 Posted April 30, 2014 Remove the ; end of file and just have it as a blank line you need the last line as blank so it acts a return ending pline for you also add look at this with snap on screws up pline. (setq oldsnap (getvar "osmode")) Osmode 0 _PLINE 22.0954,7.0898 24.4464,3.5113 30.3239,6.3703 27.7264,10.1761 31.0933,12.4671 32.6094,9.9539 36.3995,12.4066 (setvar "osmode" oldsnap) Quote
Alfred Low Posted March 26, 2019 Posted March 26, 2019 I have quite a similiar problem. My script is supposed to draw two separate polyline and write four text but it does not. Please look and see if you can pin down where I go wrong. LAYER S 1-SURCHARGE-LEVEL LINETYPE S CONTINUOUS CELTSCALE 0.60 -OSNAP OFF _PLINE -17.001,2.999 -17.001,12.264 -17.001,13.764 -17.001,22.764 TEXT J BC -17.001,21.264 0.40 0 -17.001 TEXT J BC -17.001,18.264 0.40 0 2.999 LAYER S 1-SURCHARGE-LEVEL LINETYPE S CONTINUOUS CELTSCALE 0.60 -OSNAP OFF _PLINE -16.9,2.9 -16.9,12.264 -16.201,13.764 -16.201,22.764 TEXT J BC -16.201,21.264 0.40 0 -16.900 TEXT J BC -16.201,18.264 0.40 0 2.900 Thanks Alfred Quote
BIGAL Posted March 26, 2019 Posted March 26, 2019 You need to count the returns more you need to use a blank line or a space on end, blank line is more obvious, you are not completeing commands a enter is needed to exit. Split layer and osnap can use osmode 0 but remember to set back to default You are not ending pline command either a C or blank line. Quote
