sarahdesign Posted April 28, 2014 Posted April 28, 2014 Hello, can someone please tell me what I am doing wrong? Sometimes when I dimension in paper space the dimension is slightly less that the actual dimension. Eg. If I have a 300mm line (I have double checked it in model space) it will dimension in paper space as 299.95 It is not all the time. It is driving me nuts. Does anyone know what this is? Thanks Quote
Dadgad Posted April 28, 2014 Posted April 28, 2014 Welcome to CADTutor forum! Enter UNITS at the commandline, when the dialog box comes up, change the precision, as shown in the screenshot, by clicking on the dropdown menu and selecting an appropriate precision level. When you check it in modelspace, the response you get is set to the precision level which is set in your UNITS. The DIMSTYLE which you are using has a precision level which is defined in the MODIFY dimstyle dialogue, on the PRIMARY UNITS tab, which is why they seem to be at odds with one another. Quote
sarahdesign Posted April 28, 2014 Author Posted April 28, 2014 Thank you. That didn't help in paper space, however it helped me figure out how to do it in paper space. Quote
Dadgad Posted April 28, 2014 Posted April 28, 2014 Glad that helped you resolve your issue. Are you working in Imperial or Metric units? Quote
sarahdesign Posted April 28, 2014 Author Posted April 28, 2014 metric I still don't know why this is happening and I have to change then individually. Any other suggestions? Quote
Dadgad Posted April 28, 2014 Posted April 28, 2014 If you redefine the precision in your dimstyle, rather than overwriting them in properties individually, then any dimensions which have been created previously in that dimstyle, will all change at the same time. I suggest you open this link http://www.cadtutor.net/tutorials/autocad/units-and-scales.php for a quick tutorial to help get you back on the tracks. Autocad defaults to IMPERIAL unit templates, so pay extra attention to selecting an appropriate TEMPLATE. This is addressed in the tutorial, I believe. Quote
ReMark Posted April 28, 2014 Posted April 28, 2014 When you do your dimensioning are you using your OSnaps? BTW...are your dimensions associative? Quote
RobDraw Posted April 28, 2014 Posted April 28, 2014 BTW, changing the precision only hides the issue. The inaccuracy is still there. If the drawing and viewport scale are correct, one cause could be that the objects are very far from (0,0). Quote
