longcrier Posted December 4, 2008 Posted December 4, 2008 I have drawn many contours using polylines with arcs in them. I have assigned the appropriate elevations to all these polylines. I want to create a surface with them, but it just connects the endpoints of the curve? If there is no way to create a surface with curved polylines is there a way to convert the curves to lots of little line segments? Quote
MaxwellEdison Posted December 4, 2008 Posted December 4, 2008 Do you have access to the drape command? Quote
BOB'27T Posted December 4, 2008 Posted December 4, 2008 You'll probably need to use the Lines/curves command. There are various ways of adding arcs to polylines. Quote
longcrier Posted December 4, 2008 Author Posted December 4, 2008 I'm not sure about the drape command? I'm using Civil 3D '09. Mostly I want my contours to label themselves instead of having to label them individually. As a last resort I would like to eliminate arcs/curves from the polylines as opposed to adding them. Thank you for your responses. Quote
lpseifert Posted December 4, 2008 Posted December 4, 2008 Are you defining your surface w/ Contours... look at this option (Toolspace > Prospector > Surfaces > Definition) Try decreasing the mid-ordinate distance Quote
rustysilo Posted December 5, 2008 Posted December 5, 2008 Or try feature lines. My recommendation would be to use one of the various lisps available to label the contours. If you're creating a surface from contours just so you can label contours then you're wasting time. Search for a lisp (there is one here). Label your fake contours. Be happy. Quote
longcrier Posted December 5, 2008 Author Posted December 5, 2008 I loaded the lisp through cui and appload. Is that overkill? Now how do I label the contours? I've never used lisps before. Quote
rustysilo Posted December 5, 2008 Posted December 5, 2008 For that one you would type in clbl and enter, but when I try it it appears to be looking for another lsp or perhaps an outdated command svlayr so not sure. I thought you could label polylines as you would a contour, but I must be thinking of Land Desktop that allowed that. Quote
