dbroada Posted April 28, 2014 Posted April 28, 2014 YAYYY!!! you may want to set up some other .ctb files. Our standard one has all lines set to print black with the linewidths set by their colour. I have a couple of variations for when the toner is almost empty or brand new. Quote
RobDraw Posted April 28, 2014 Posted April 28, 2014 May require some fiddling still though because it makes all the lines come out really light. But I'm sure I can manage that! Thanks for everyones help! Create a .ctb file. Do not modify any of the OTB ones. You can use one to start with but save it as a different name. Quote
Barneel Posted April 28, 2014 Author Posted April 28, 2014 That's a good idea, dbroada. Will look into making some more now No need for now, RobDraw. Have resolved the issue simply by allowing for line weights in the macro (it was disabled before). See final macro: ^C^C-plot;y;;SGT_PRINTY;A3 297 x 420 mm;M;L;N;E;F;C;Y;monochrome.ctb;Y;A;N;N;Y; Quote
