Vagulus Posted April 24, 2014 Posted April 24, 2014 A couple of queries about being fully constrained: Consider the attached part. Edit Sketch 1. Display all Constraints. What two dimensions are missing? Change Horizontal Dimension (vertical axis to arc centre) to 150. This distorts the arcs on my Inventor 2015. Why is this? Thanks Underconstrained_Part.iptFetching info... Quote
JD Mather Posted April 24, 2014 Posted April 24, 2014 I don't see any Tangent Constraints. Not one? How can the arcs be forced to remain Tangent without any Tangent constraints? If you had use the Sketch Slot tool to create this - Inventor would have taken care of the tangents for you (there is another way too, but it requires some expert knowledge). Quote
