Baiksu Posted April 17, 2014 Posted April 17, 2014 I have a DWG file that is looking for Helvetica font. Where can I find this font for AutoCAD Quote
MSasu Posted April 17, 2014 Posted April 17, 2014 You will need to check also the extension of said missing font (call STYLE command). If is Helvetica.TTF, then is a Windows font and should be installed by Control Panel; if is Helvetica.SHX, then goes in AutoCAD\Fonts folder. For sure a search on Internet will allow you to locate the file, but you will have to validate also his copyright status before installing. Quote
