some persons sent me CAD files , when i tried to open them , at once AutoCAD crashed and an error message appeared ...
Autocad 2012
is there a way to check if the CAD file contains virus or not ??
- Repairing didn't work !! , only unistalling solved the problem , but when tried to open the file again , the program crashed :(
0x0020 errors are typically caused by driver errors, so it could indicate a driver conflict on your computer, or it could be a problem with the file that's causing a the error. I would try Cad64's suggestion first. If that doesn't work, try disabling Hardware Acceleration in AutoCAD before opening the file. If that still fails, perhaps attach the file here so we may check if we also have trouble opening the file.
