Salama Posted April 13, 2014 Share Posted April 13, 2014 some persons sent me CAD files , when i tried to open them , at once AutoCAD crashed and an error message appeared ... Autocad 2012 is there a way to check if the CAD file contains virus or not ?? - Repairing didn't work !! , only unistalling solved the problem , but when tried to open the file again , the program crashed Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 13, 2014 Share Posted April 13, 2014 Try opening the file using the RECOVER command: http://autocadtips.wordpress.com/2012/10/17/recover-a-drawing/ Quote Link to comment Share on other sites More sharing options...
nestly Posted April 13, 2014 Share Posted April 13, 2014 0x0020 errors are typically caused by driver errors, so it could indicate a driver conflict on your computer, or it could be a problem with the file that's causing a the error. I would try Cad64's suggestion first. If that doesn't work, try disabling Hardware Acceleration in AutoCAD before opening the file. If that still fails, perhaps attach the file here so we may check if we also have trouble opening the file. Quote Link to comment Share on other sites More sharing options...
