Dimensioning style problems
Here is what I'm trying to do:
Set my dimensioning style to Decimal, with Suffix ", so that my distance dimensions show, for instance: . Pretty straightforward, except that my angular dimensions now show: . The suffix " is added also to angular dimensions as well as distance dimensions.[/size][/font]
I can almost get what I want by choosing Engineering unit format, except that I don't want feet -inches, I just want inches.
Thanks
Bill
You could create a new style specifically for ANGULAR DIMS, without the suffix, and you should be good to go.
While naming and defining this new dimstyle, select USE FOR ... Angular Dimensions.
Thank, Dadgad. I thought I was doing something wrong...
Your solution is a good one, appreciate your help.
Bill
