andyg Posted April 9, 2014 Share Posted April 9, 2014 Evening all, Hi I'm struggling with a hinge type mate so if you please a little help will be greatly appreciated.... I have a frame sitting inside a reveal in a wall with two pins sticking out of the frame top and bottom to go into the wall and work as a simple hinge. I can mate everything to work fine as just a normal hinge mate however the frame does not touch the wall it sits central with a 20mm gap all the way around it, so when I chose the "coincidence selections" in the hinge mate tab the face of the frame touches the reveal. How can I combine the hinge mate but still keep the result of the width mate that puts the frame central into the the reveal with its 20mm gap all the way around the outside. Soildworks 2012 64 bit. Thanks in advance for any help you can give. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 9, 2014 Share Posted April 9, 2014 Attach your assembly here. Quote Link to comment Share on other sites More sharing options...
andyg Posted April 10, 2014 Author Share Posted April 10, 2014 Here are the files I am using, the whole thing should basically be a cupboard door to make it simple. Assemclosed.SLDASM SS Frame.SLDPRT Wall.SLDPRT Quote Link to comment Share on other sites More sharing options...
Ubatoid Posted April 11, 2014 Share Posted April 11, 2014 Have you tried using a distance mate of 20mm from the bottom face of the door to the wall? and then using a concentric mate for the hinge pin and hole? Quote Link to comment Share on other sites More sharing options...
