Autocad 2014
Something changed. I could individually select numerous objects individually then pan around the drawing without losing the selected objects.
Now, I can select various individual objects, with no active commands, and as I start to pan, without moving the selected objects off screen, I lose all the selected objects.
Thoughts?
  • 1 year later...
  On 2/18/2020 at 7:07 PM, Tallman said:
Autocad 2014
Thoughts?
Expand
Are you still using AutoCAD 2014? SELECTIONOFFSCREEN wasn't introduced until the 2018 version.
Did you try all the suggestions on the first page?
  • 2 years later...
Had the same problem and this is how I solved it:
Problem: I click to start selecting, then zoom in to click again to end the selection, type the command (ex. Move) and only the objects that I see will actually move.
Solution: turn  SELECTIONOFFSCREEN to 1
