Tallman Posted February 18, 2020 Posted February 18, 2020 Autocad 2014 Something changed. I could individually select numerous objects individually then pan around the drawing without losing the selected objects. Now, I can select various individual objects, with no active commands, and as I start to pan, without moving the selected objects off screen, I lose all the selected objects. Thoughts? Quote
Vivi Posted April 12, 2021 Posted April 12, 2021 Change the variable SELECTIONOFFSCREEN to 1. 1 Quote
tombu Posted April 14, 2021 Posted April 14, 2021 On 2/18/2020 at 7:07 PM, Tallman said: Autocad 2014 Something changed. I could individually select numerous objects individually then pan around the drawing without losing the selected objects. Now, I can select various individual objects, with no active commands, and as I start to pan, without moving the selected objects off screen, I lose all the selected objects. Thoughts? Expand Are you still using AutoCAD 2014? SELECTIONOFFSCREEN wasn't introduced until the 2018 version. Did you try all the suggestions on the first page? Quote
Brenda Posted January 25, 2024 Posted January 25, 2024 Had the same problem and this is how I solved it: Problem: I click to start selecting, then zoom in to click again to end the selection, type the command (ex. Move) and only the objects that I see will actually move. Solution: turn SELECTIONOFFSCREEN to 1 1 Quote
