what is superpurge how to installed in autocad 2014LT?
I doubt that it will work. I think it is a lisp program.
SuperPurge can be found here....http://www.manusoft.com/software/superpurge.html
At least you can read up on it.
Explode all blocks then purge does the work too.
Unless you don't mind others using your blocks.
thnx for yours replay, i did that to explode to create a block but i want to open proxy object that i dont know how to do.. i haired that was separate exe file want to down load to "super purge" then can do.. ..
You got us going on the wrong thing if you are referring to the block in the template with the block attribute in order for you to fill then you lost me along the way.
Therefore if you click on the Block you should be able to enter the data in order to get the text wanted in the boxes .
Then again without the cad file i cannot help. unless i am mistaking.
Remark can possibly help you on that if he understood your seek
