arunz Posted April 6, 2014 Posted April 6, 2014 Dear all, i can't to edit block when i edit i got the message like this... how to do this? Quote
MSasu Posted April 7, 2014 Posted April 7, 2014 This is because that item was created by a different application (a vertical product or a third-part tool) and therefore contains custom entities for which AutoCAD doesn't have the appropriate capabilities to access. If you know the source of that drawing may get a so called enabler - although I'm not sure if is possible to make it work with LT. Quote
ReMark Posted April 7, 2014 Posted April 7, 2014 Re: Proxy Objects. Read this...http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-6515268E-3D71-4CBC-8D3C-2059CFAA4E38.htm,topicNumber=d30e131447 Quote
