CADLee Posted April 5, 2014 Share Posted April 5, 2014 I am trying to make some electrical symbols for a floor plan I am doing. I want to make the switch symbols. Two-way, three-way, and four-way. I can make the "S" and then the number beside it. "S2, S3, S4. Text is really no problem. But I want to make the number little the way they should be if they were drawn manually. Like the number above the "S" and to the right, but smaller. How do I do this? Thank You for the help. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 5, 2014 Share Posted April 5, 2014 You want to draw a label with two characters, each with its own height? S5 The MTEXT command will allow you to control the height independent by character. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2014 Share Posted April 5, 2014 Since it is going to be a block I would use plain Text not MText and I would make both the "S" and the number separate text entities. This will give you all the leeway you need to place the 2, 3, etc. wherever you want. Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 6, 2014 Share Posted April 6, 2014 MText has the option to add special characters click on the @ symbol and down at the bottom of the drop list select the option for other, this opens up windows character map, scroll down and find the symbol you want double click on the symbol and close the character map and paste (Ctrl+v). As a hint the symbols 1,2,3 are near the top of the list and 0,4,5,6,7,8,9 are near the bottom. Quote Link to comment Share on other sites More sharing options...
