Hi,
I was messing about with my CUI yesterday and found that there wasn't an icon for the Mid between 2 points object snap. I had a go at making one and thought I'd share it here for others to use.
I based it on existing icons and it's basically 2 points with 2 orange arrows pointing to the mid point between them.
Unfortunately I was unable to upload it in it's original .bmp format, so I had to convert it to .png. I'm not sure if .png files can be used in AutoCAD or if it will need converting back to .bmp format.
Thank you for sharing!
If you don't mind, I would make a small correction - that isn't actually an Osnap mode, but rather a command modifier.
True, perhaps that's why there isn't an icon for it.
Although I just lump it in with Osnaps as it's used within their context and it's included in the Osnap toolbar.
Very nice never thought about it but often use it, for anyone interested see next line
M2P [_Button("M2P","M2P.BMP","M2P.BMP")](command "M2P")
ps use caps BMP in name, used paint to convert.
