bababarghi Posted March 28, 2014 Posted March 28, 2014 Hopefully I have created the thread in the right place. I was wondering if there is any system/environment variable to disable accessing online content? (I need to disable this feature via my lisp code) Quote
zaphod Posted March 28, 2014 Posted March 28, 2014 seem to be different on every version of autocad this might be of some help http://otb.manusoft.com/2009/03/disable-infocenter-in-autocad-2010.htm Quote
bababarghi Posted March 30, 2014 Author Posted March 30, 2014 (edited) Found the answer here. WBHELPONLINE is the undocumented variable name. However that is a Read Only variable. Edited March 31, 2014 by bababarghi Quote
RobDraw Posted March 31, 2014 Posted March 31, 2014 Then it doesn't really answer your question. Does that mean there isn't a variable to control it? Why LISP? Isn't that setting stored in your profile so that once you change it the setting sticks? Quote
bababarghi Posted March 31, 2014 Author Posted March 31, 2014 You are right. Not really addressed my issue. So far, that's the only clue I found in regard to online access permissions. LSP deployment is preferred because I need to push lots of settings to new CAD machines in our office e.g support paths, template paths, printer configs, etc. Disabling online access is also one the items which needs to be applied on new machines. I have a feeling that, at the end of the day, I need to pursuit Registry editing solutions (which is not preferred at all) Quote
ReMark Posted March 31, 2014 Posted March 31, 2014 Are you referring to the InfoCenter also called the CommCenter? Quote
bababarghi Posted March 31, 2014 Author Posted March 31, 2014 The intent is to be able to bring up 'offline' help window by pressing F1 key. Quote
ReMark Posted March 31, 2014 Posted March 31, 2014 Ahhhh, I see. Now we are getting to the crux of the matter. Clarity provides direction. Quote
RobDraw Posted March 31, 2014 Posted March 31, 2014 (edited) Granted I don't get much involved with the network stuff and this may be "old school" but don't you have a default profile that can be loaded at any time for setting/resetting paths, variables, etc.? Edited March 31, 2014 by RobDraw Quote
BlackBox Posted March 31, 2014 Posted March 31, 2014 However that is a Read Only variable. Is it now... Give this a try: (vl-load-com) (defun c:OnlineContentOff () (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (if vlax-user-product-key ; If 2013 (vlax-user-product-key) ; Use 2013 function (vlax-product-key) ; Use legacy function ) "\\Profiles\\" (getvar 'cprofile) "\\Variables\\" ) "WBHELPONLINE" 0 ) (alert (strcat "Online content has been disabled.\n\n" "Please restart your session for these changes to take effect. " ) ) (princ) ) Quote
BlackBox Posted March 31, 2014 Posted March 31, 2014 Are you referring to the InfoCenter also called the CommCenter? ... And since it is loosely related to this thread: (vl-load-com) (defun c:InfoCenterOff () (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (if vlax-user-product-key ; If 2013 (vlax-user-product-key) ; Use 2013 function (vlax-product-key) ; Use legacy function ) "\\InfoCenter" ) "InfoCenterOn" 0 ) (alert (strcat "InfoCenter has been disabled.\n\n" "Please restart your session for these changes to take effect. " ) ) (princ) ) Quote
bababarghi Posted April 1, 2014 Author Posted April 1, 2014 Works perfectly fine except the the RED coloured bit highlighted at following code. The value should be string Is it now... Give this a try: (vl-load-com) (defun c:OnlineContentOff () (vl-registry-write (strcat "HKEY_CURRENT_USER\\" (if vlax-user-product-key ; If 2013 (vlax-user-product-key) ; Use 2013 function (vlax-product-key) ; Use legacy function ) "\\Profiles\\" (getvar 'cprofile) "\\Variables\\" ) "WBHELPONLINE" [color="red"][b]"[/b][/color]0[color="red"][b]"[/b][/color] ; [color="red"]<------This line needed a couple of (")[/color] ) (alert (strcat "Online content has been disabled.\n\n" "Please restart your session for these changes to take effect. " ) ) (princ) ) Quote
BlackBox Posted April 1, 2014 Posted April 1, 2014 Strange - in 2014 it appeared to be int(-eger) from RegEdit view. Especially so, given that InfoCenterOff requires same. Guess that's what I get for writing code in the post editor and not testing. LoL In any event, I'm glad you got it sorted, and thank you for the clarification. Cheers Quote
