jcabmakr66 Posted March 27, 2014 Posted March 27, 2014 Is it possible to add new hatch patterns to LT? I tried and can not get it to work. Any help would be appreciated. Thanks Quote
ReMark Posted March 27, 2014 Posted March 27, 2014 Yes, by adding them to the acadlt.pat (I think that is the correct name) file. Of course you have to edit the correct file. Quote
steven-g Posted March 28, 2014 Posted March 28, 2014 It is possible you can add a new hatch to the acadlt.pat file as ReMark says, or you can create a seperate .pat file but it has to be saved into the support path. http://www.ellenfinkelstein.com/acadblog/creating-custom-hatch-patterns/ gives a good description about creating hatch patterns. It can get confusing though, if you get stuck just give a shout and post your text file along with an example sketch, I'm sure someone will be able to point you in the right direction. Quote
