Picking just one is a real challenge, but in my case it would definitely be one of Lee Mac's.
I just can't decide which one .... oh well, LAYER DIRECTOR it is then,
http://www.lee-mac.com/layerdirector.html
since it is always running when I am working, unlike others which I use when needed.
Thanks Lee! :beer:
  • Replies 37
  • Tharwat
    4
  • paulmcz
    3
  • Rob-GB
    3
  • Nobull84
    3
Says youtube link is "private"
1+
Share source, Jdiala? Looks like a cool and useful prog\
pm'ing my email.
  • 2 weeks later...
  Rob-GB said:
My favourite is my Stair lisp, because it was my first and I was given advice jointly by members here and over at the swamp.(some overlap of members is more than probable ;) ) It reminds me both of my accomplishment and the huge generosity of the members of these forums for which I am thankful.
Rob.
Hey Rob-GB! Could you be so kind and show a screenshot of the results of your stair lisp?
Here is a good lisp:
(defun c:cad ()
 (command "BROWSER" "http://www.cadtutor.net/")
All Lee Mac's lisps can be named in this thread I suppose but I use BFIND and BATTE the most.
  • 3 years later...
ROBP,
Can you send me some lisp?
about: screw conveyor and concentric cone?
Thanks.
Edwin
I use this daily:
;; Open folder current directory
(defun c:cd (/ _opendirectory)
 (defun _opendirectory	(path / sa)
   (if	(and (eq 'str (type path))
     (findfile (vl-string-right-trim "\\" path))
     (setq sa (vlax-create-object "Shell.Application"))
     (progn (vlax-invoke sa 'explore path) (vlax-release-object sa))
 (_opendirectory (getvar 'dwgprefix))
  ronjonp said:
I use this daily:
I used this one:
; To Display / Open the current / active dwg in explorer, to see where its located
(defun C:test ( / )
 (cond
   ( (zerop (getvar 'dwgtitled)) (alert "\nThis drawing is not saved!") )
   ( (startapp (apply 'strcat (append '("explorer /select, ") (mapcar 'getvar '(dwgprefix dwgname)) '(", /e")))) )
 ); cond
); defun C:test
But I always forget how I named the .lsp file or the command definition so just write (getvar 'dwgprefix) to see on what dwg I'm working on.
  mstg007 said:
http://www.lee-mac.com/incrementalarray.html
Make sure you use the "The dynamic mode: incarrayd". This one ROCKS!
Use it ALOT and thanks Lee!
Judging by Lee's background - which is automating work for different companies,
even if you don't know what your favourite lisp is he would find a way to save you so much time and effort,
so even hiring additional work(ers) won't worth it. ;)
Simplest is the best I think.
The ones I use daily are:
"ZA".... Zoom All wihch wouldn't take a genius to work out
A3P... A3 Plot send a plot to the A3 printer and PLOTPDF saves a PDF in the same folder as the drawing (these are my first 2 so the code probably isn't the best, but they work)
(command "shell" (strcat "explorer \"" (getvar 'dwgprefix) "\""))
my fav is Doug Wilson's transpose = (apply 'mapcar (cons 'list lst))
My new favorite
This toggle for a classic toolbar
; TOGGLE TOOLBAR CONTROL
(defun c:-TB-ins ()
   (if (null -tb-ins)
       (setq -TB-ins 0)
   (setq -TB-ins (abs (- 1 -tb-ins)))
   (if (= -TB-ins 0)
       (COMMAND "-TOOLBAR" "CONTROL" "hide")  ; CONTROL: jouw custom toolbar
       (COMMAND "-TOOLBAR" "CONTROL" "show")  ; CONTROL: jouw custom toolbar
https://drive.google.com/file/d/1ty_ARHfa1EAfzkwahX0CJv_dZrLhskIx/view
  • 4 weeks later...
couple of goodies..
copy print settings from current layout sheet to all others (this has saved me huge amount of time!)
(defun c:CSTP  ( / Adoc Layts clyt)
     (setq aDoc  (vla-get-activedocument (vlax-get-acad-object))
           Layts (vla-get-layouts aDoc)
           clyt  (vla-get-activelayout aDoc))
     (foreach
            itm  (vl-remove (vla-get-name clyt) (layoutlist))
           (vla-copyfrom (vla-item Layts itm) clyt)
Quick Rotate - rotates selected objects 90degrees around centerpoint of object
With every click or enter pressed next rotation is made.
QR.lspFetching info...
oh I've been looking for something like this forever! always thought autocad should have an option to do that..
