callvey Posted March 24, 2014 Author Share Posted March 24, 2014 Yes it works now, thanks very much again. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 24, 2014 Share Posted March 24, 2014 Yes it works now, thanks very much again. Good stuff Quote Link to comment Share on other sites More sharing options...
johmmeke Posted July 7, 2014 Share Posted July 7, 2014 (edited) first of all, sorry to respond on a old thread. I use the routine from Tharwat in #9 When i use this in acad 2014, all my attribute values are set back to default. Do i have a setting wrong? This has been working really fine in acad 2012. Greetz John Edited July 7, 2014 by johmmeke Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 7, 2014 Share Posted July 7, 2014 I modified the routine in post #9 since that is the one you are using and added a few lines of codes to reset the same text strings of block's attributes that are in a drawing . try it and let me know . (defun c:Test (/ *error* cmd l a lst f h nm bks v cmd ss) ;; Tharwat 07. 07 . 2014 ;; (defun *error* (msg) (if cmd (setvar 'CMDECHO cmd) ) (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*") (princ msg) (princ (strcat "*** Error : " msg "***")) ) (princ) ) (or doc (setq doc (vla-get-activedocument (vlax-get-acad-object))) ) (setq cmd (getvar 'CMDECHO) l '(("AREA1" . "AREA13") ("AREA2" . "AREA14") ("AREA3" . "AREA15") ("AREA4" . "AREA16") ("AREA5" . "AREA17") ("AREA6" . "AREA18") ("AREA7" . "AREA19") ("AREA8" . "AREA20") ) ) (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1)))) ((lambda (i / sn f) (while (setq sn (ssname ss (setq i (1+ i)))) (foreach tg (vlax-invoke (vlax-ename->vla-object sn) 'GetAttributes ) (if (setq f (assoc (strcase (vla-get-tagstring tg)) l)) (setq lst (cons (list sn (cdr f) (vla-get-textstring tg)) lst) ) ) ) ) ) -1 ) ) (if lst (progn (vlax-for x (vla-get-blocks doc) (if (and (eq :vlax-false (vla-get-isxref x)) (eq :vlax-false (vla-get-islayout x)) ) (vlax-for o x (if (and (eq (vla-get-objectname o) "AcDbAttributeDefinition") (setq a (assoc (strcase (vla-get-tagstring o)) l)) ) (progn (vla-put-tagstring o (cdr a)) (if (not (member (setq nm (vla-get-name x)) bks)) (setq bks (cons nm bks)) ) ) ) ) ) ) (setvar 'CMDECHO 0) (mapcar '(lambda (n) (command "_.attsync" "_Name" n)) bks) (setvar 'CMDECHO cmd) (foreach x lst (foreach tg (vlax-invoke (setq v (vlax-ename->vla-object (car x))) 'GetAttributes ) (if (and (eq (strcase (vla-get-tagstring tg)) (strcase (cadr x))) (vlax-write-enabled-p v) ) (vla-put-textstring tg (caddr x)) ) ) ) ) ) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
johmmeke Posted July 7, 2014 Share Posted July 7, 2014 thank you works perfect again. This is a great help me, i often get drawing where the tag name's are not consistant. Thx again for the help, JOhn Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 7, 2014 Share Posted July 7, 2014 thank you works perfect again. This is a great help me, i often get drawing where the tag name's are not consistant. Thx again for the help, JOhn Excellent . You're welcome John and I am really happy to help . Quote Link to comment Share on other sites More sharing options...
johmmeke Posted July 8, 2014 Share Posted July 8, 2014 Tharwat, one thing i come across is that the routine is not working on dynamic block's. This is not so import to me, just to let u know. John Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 8, 2014 Share Posted July 8, 2014 Tharwat, one thing i come across is that the routine is not working on dynamic block's. This is not so import to me, just to let u know. John That is correct , and I do know that John Simply due to the name of the dynamic block that can not be retrieved by the function vla-get-name which strongly supports my saying and would fail with Dynamic Blocks Quote Link to comment Share on other sites More sharing options...
7o7 Posted July 8, 2014 Share Posted July 8, 2014 Tharwat, Although You can get the dynamic block by name, you can change it's tag name, but it doesn't effect its "child" dynamic blocks, because they are independent from their "parent". If you want to change tag name, you have to change every "child" block, not only their "parent". Try this: (defun c:test(/ l en tm) (setq l '(("AREA1" . "AREA13") ("AREA2" . "AREA14") ("AREA3" . "AREA15") ("AREA4" . "AREA16") ("AREA5" . "AREA17") ("AREA6" . "AREA18") ("AREA7" . "AREA19") ("AREA8" . "AREA20") ) ) (foreach en (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget "X" '((0 . "INSERT") (66 . 1)))))) (while (and (setq en (entnext en)) (/= (cdr (assoc 0 (entget en))) "SEQEND")) (if (and (= (cdr (assoc 0 (entget en))) "ATTRIB") (setq tm (assoc (cdr (assoc 2 (entget en))) l))) (entmod (subst (cons 2 (cdr tm)) (assoc 2 (entget en)) (entget en)))) ) ) (princ) ) Hope this can help. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 8, 2014 Share Posted July 8, 2014 @7o7 I wonder what 's new in your routine to mine ? Quote Link to comment Share on other sites More sharing options...
7o7 Posted July 9, 2014 Share Posted July 9, 2014 The difference is you try to catch the block by name and to use the "attsync" command of cad, it change blocks to their default properties, such as color,.. My code is just surfing through each block, change only its tag name, and leave other properties unchanged. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 9, 2014 Share Posted July 9, 2014 The difference is you try to catch the block by name and to use the "attsync" command of cad, it change blocks to their default properties, such as color,..My code is just surfing through each block, change only its tag name, and leave other properties unchanged. Correct , and I know that I took the long way to reach the destination but it is okay since that we got what we want . But you may need to add a few codes to change the PARENT blocks' tag names as well as the CHILDREN 's did . Quote Link to comment Share on other sites More sharing options...
NoamBrand Posted January 13, 2019 Share Posted January 13, 2019 Synchronizing attributes reverts the existing values to default This is a big problem with the lisp Quote Link to comment Share on other sites More sharing options...
nikita2597 Posted September 21, 2020 Share Posted September 21, 2020 Nice script. is it also posible to rename the tagname without losing the already filled-value of the tag. Quote Link to comment Share on other sites More sharing options...
