Sengna Posted March 20, 2014 Share Posted March 20, 2014 Hi, Is there a way for me to get,customize or import the regular linear construction line? for example: if when i need i just click on the construction line tool and it will work either vertical or horizaltal, i used to be able to do in different version of cad but not on this 2010 autocad that i have. when i click then window pop up and show me all type of const lines i don't want all. Greatly appreciate any suggestion thanks. Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 21, 2014 Share Posted March 21, 2014 That dialog is specific to Mechanical pack (and probably other vertical products); if you want the behavior of Vanilla’ AutoCAD, then try to use XLINE command instead. Quote Link to comment Share on other sites More sharing options...
Sengna Posted March 21, 2014 Author Share Posted March 21, 2014 That dialog is specific to Mechanical pack (and probably other vertical products); if you want the behavior of Vanilla’ AutoCAD, then try to use XLINE command instead. Hi, MSasu, as you can see on the attached pic, top right corner, i am on Xline command mode. unless you mean other Xline, if that is the case, where can i get it? thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted March 21, 2014 Share Posted March 21, 2014 Use AMCONSTXLINE command, add that in your CUI where ever you like, or .pgp, etc. Quote Link to comment Share on other sites More sharing options...
