grain Posted March 20, 2014 Posted March 20, 2014 Hi, There doesn't seem to be an option to plot to PDF with layers. (I have gone into the custom properties but there is no option to 'retain layer information'. Thats using PDF to Dwg.pc3 I also have CutePDF Writer that doesnt have the option either. Maybe you have to get Acrobat Pro? Quote
steven-g Posted March 20, 2014 Posted March 20, 2014 Take a look at publish rather than plot, I can get at that in the publish options. Quote
grain Posted March 20, 2014 Author Posted March 20, 2014 Hi Steven, I only seem to be able to Publish to the DWF electronic format. Quote
grain Posted March 20, 2014 Author Posted March 20, 2014 Thanks anyway. I'll probably look into some more advanced PDF software. Quote
lamensterms Posted March 20, 2014 Posted March 20, 2014 Hi grain, If you cannot retain layer information while publishing from ACAD 2009 (or earlier)... You could just install DWG TrueView and use that for all your publishing. You should be able to publish to PDF and keep your layers, no worries. Good luck. Quote
grain Posted March 20, 2014 Author Posted March 20, 2014 Thanks Lamensterms. That works perfectly. Quote
