sajicor Posted March 24, 2014 Author Posted March 24, 2014 (edited) The Annotation Scale in Modelspace will need to be adjusted to match any of the scaled layouts you may have in Paperspace. This is your "Working Space" so to speak, and is usually not a permanent space for linetype scales. Ok, I understand now how it works using annotative text and dimensions. Thanks Edited March 24, 2014 by sajicor completing info Quote
RobDraw Posted March 24, 2014 Posted March 24, 2014 When working with multiple viewports of varying annotative scales, best practice is to work through the viewport. That way, you don't have to worry about changing settings, multiple displays of the same object, linetype scale display, etc. Quote
ReMark Posted March 24, 2014 Posted March 24, 2014 When working "through" a viewport I'd recommend locking the viewport display so you do not inadvertently change the viewport scale. This is done via the Display Locked option when you right click on a viewport. Quote
