lkenshalo Posted March 18, 2014 Posted March 18, 2014 My architecture won't show as any other visual style other than hidden line or wire frame in a systems default template - is this the standard for this type of template? Are there any options I can change to allow my architecture to show up as shaded? Keep in mind that the systems(mechanical equipment) show in the various visual styles. Thanks in advance! Quote
tzframpton Posted March 18, 2014 Posted March 18, 2014 My architecture won't show as any other visual style other than hidden line or wire frame in a systems default template - is this the standard for this type of template? Are there any options I can change to allow my architecture to show up as shaded? Keep in mind that the systems(mechanical equipment) show in the various visual styles. Thanks in advance! You have five Disciplines for each View: Architectural, Coordination, Mechanical, Electrical and Plumbing. Only Architectural and Coordination will show everything shaded. Mechanical, Electrical and Plumbing - Revit automatically overrides all non-MEP items as a screened mode with no shading. This is an internal setting and cannot be changed. Quote
lkenshalo Posted March 18, 2014 Author Posted March 18, 2014 Thanks a bunch TZ - I was hoping for a work around! Leon Quote
tzframpton Posted March 18, 2014 Posted March 18, 2014 Thanks a bunch TZ - I was hoping for a work around! Leon No need for a workaround. The Discipline is really for organizational purposes. If you still want the View to be classified as "Mechanical" then do a little rearranging with your Project Browser Filters. Quote
