flopo Posted October 20, 2011 Share Posted October 20, 2011 Hi guys, Thanks to Paulmcz - the author for original lisp, and Fuccaro - who modified it for me, i post now two lisps - one for pipe + elbows, the other for pipes+curves. For me they works perfect, i hope the same for you. pipes+elbows.LSP pipes+ curves.LSP Quote Link to comment Share on other sites More sharing options...
anduc Posted October 21, 2011 Share Posted October 21, 2011 Hi Flopo,.. Not bad,.....but why using autocad command against creating object entity ? If you use AutoCAD command, I strongly suggest you to put "._" before the command name and "_" before the option. Also, maybe removing snaps with the "_non" options. eg: (command "._line" "_non" p1 "_non" p2 "") this will prevent you the non compatible mode when sharing your tool with other using AutoCAD in other language. But,...It work fine on autoCAD 2010 english. Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
flopo Posted October 24, 2011 Share Posted October 24, 2011 Hi guys, For this two lisps postet above, i need a little help. I want them modified this way: to replace command c:bd (as is now) with something like ... bd400600, where 400 is pipe diameter and 600 is bend radius ( and, of course, to erase from the lisp those 2 setq for diameter and radius). And , when i use command bd500800, not to be asked to insert diameter and radius. Please help. Thanks! Quote Link to comment Share on other sites More sharing options...
paulmcz Posted October 26, 2011 Share Posted October 26, 2011 Hi guys,For this two lisps postet above, i need a little help. I want them modified this way: to replace command c:bd (as is now) with something like ... bd400600, where 400 is pipe diameter and 600 is bend radius ( and, of course, to erase from the lisp those 2 setq for diameter and radius). And , when i use command bd500800, not to be asked to insert diameter and radius. Please help. Thanks! Did anyone help you with this Flopo? pipes+elbows400600+500800.LSP Quote Link to comment Share on other sites More sharing options...
flopo Posted October 26, 2011 Share Posted October 26, 2011 Hi Paul, Yes, Fuccaro helped me. Again, problem with english - these 2 lisps above that you modified - is not what i want. I don't want a fix value for diameter and radius - i just want a new command - does't matter the value of diameter and radius, but, when i use the new command, i want to be able to insert at the same time diameter and radius, - whose values are not fix. So, let's say i insert the command.... bd400500 - and the lisp will draw using 400 for diameter and 500 for radius. Then, using the same lisp, i insert bd700900 - and the same lisp will draw using 700 for diameter and 900 for radius - i mean, instead of working like this : insert command bd, the the lisp ask me for diameter, then for radius - i want to insert values for diameter and radius together with the command, but my lisp to be able to work with different values, not fix values. I don't know if is possible. Thanks! Quote Link to comment Share on other sites More sharing options...
AceV Posted October 27, 2011 Share Posted October 27, 2011 Hey guys! This thread is everything I've been searching for and has been a huge help! Thank you to all of you! I was wondering if it were at all possible to have an option for a single duct to branch off into two different ducts (in a sort of Y shape) as part of the LISP? Any tips would be hugely appreciated Quote Link to comment Share on other sites More sharing options...
Ronso Posted January 10, 2012 Share Posted January 10, 2012 Once again I have incorporated a few of the requests into the programming. Now allows for elbow centerlines. WPIPE[10].LSP Quote Link to comment Share on other sites More sharing options...
alanjt Posted January 10, 2012 Share Posted January 10, 2012 lol The thread that never dies. Quote Link to comment Share on other sites More sharing options...
Ronso Posted January 11, 2012 Share Posted January 11, 2012 flopo, In responding to your request, a lisp command will only accept arguments through command line inputs. What I believe you seek is a lisp function which can accept the arguments up front. Load the lisp attached to this reply. Per your examples: Keying in at the command line (bd 400 500) the lisp will draw using 400 for diameter and 500 for radius. Keying in at the command line (bd 700 900) the lisp will draw using 700 for diameter and 900 for radius. WPIPE[11].LSP Quote Link to comment Share on other sites More sharing options...
flopo Posted January 12, 2012 Share Posted January 12, 2012 Ronso, This is what i was searching for. Thanks! Quote Link to comment Share on other sites More sharing options...
JONTHEPOPE Posted May 14, 2012 Share Posted May 14, 2012 How could this programm be edited to show a smaller diameter elbow? Quote Link to comment Share on other sites More sharing options...
jgoutier86 Posted June 6, 2012 Share Posted June 6, 2012 Never tried to input text into wpipe? Quote Link to comment Share on other sites More sharing options...
Ronso Posted June 7, 2012 Share Posted June 7, 2012 How could this programm be edited to show a smaller diameter elbow? I am not sure I understand your question. Can you please clarify? Quote Link to comment Share on other sites More sharing options...
jgoutier86 Posted June 7, 2012 Share Posted June 7, 2012 I am not sure I understand your question. Can you please clarify? I find that lisp incredable, but to save more time in hvac drawings, it would be more complete lisp with text input in middle on the pipe! It could ask the depth each time there's a transition... So he could input text at each clicks... Sorry for my english, I'm not used to talk it. Quote Link to comment Share on other sites More sharing options...
jgoutier86 Posted June 7, 2012 Share Posted June 7, 2012 Oops question wasn't for me i think Quote Link to comment Share on other sites More sharing options...
tzframpton Posted June 7, 2012 Share Posted June 7, 2012 I find that lisp incredable, but to save more time in hvac drawings, it would be more complete lisp with text input in middle on the pipe! It could ask the depth each time there's a transition... So he could input text at each clicks... Sorry for my english, I'm not used to talk it.Look into AutoCAD MEP. Quote Link to comment Share on other sites More sharing options...
jgoutier86 Posted June 7, 2012 Share Posted June 7, 2012 Look into AutoCAD MEP. Sorry to be a little newbie, but i use the basic autocad at work.... U mean I can do it (duct and dim) on autocad mep? Thanks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 8, 2012 Share Posted June 8, 2012 Sorry to be a little newbie, but i use the basic autocad at work.... U mean I can do it (duct and dim) on autocad mep? http://usa.autodesk.com/autocad-mep/ Quote Link to comment Share on other sites More sharing options...
tzframpton Posted June 8, 2012 Share Posted June 8, 2012 Sorry to be a little newbie, but i use the basic autocad at work.... U mean I can do it (duct and dim) on autocad mep?Yep. Plus a whole 'lot more. http://usa.autodesk.com/autocad-mep/Thanks for the link Lee. @jgoutier, download the trial and have a whirl. Quote Link to comment Share on other sites More sharing options...
srinu98 Posted June 23, 2014 Share Posted June 23, 2014 please post the ducting programme for one side reducer Quote Link to comment Share on other sites More sharing options...
