mvrp350 Posted March 12, 2014 Posted March 12, 2014 Hello, I'm having a hard time finding the solution for my problem. I want to create a dynamic block in Autocad 2014 In this block I need to determine the intersection between 2 lines. In the sample you'll see my problem. I want to make A, B and C variables in my block. The angle on top is always 90 degrees. With this information I can draw everything, but I don't know how to make the intersection properly, and keep it clean when manipulating the variables. Variable A has to be positive between 1 and 89 degrees, there are no restrictions on the variables C. Any help is much appreciated mvrp350 intersection problem.dwgFetching info... Quote
