revit 2009 fatal error prompt
i got a copy of revit 2009 from the autodesk website. i installed the product and registered the copy. when i use the software after about 5 mins, a prompt shows stating that a fatal error has occured and that the program has to shut down. i dont have time to redownload the software again. is this problem fixable? what can be done?
I'd check the AutoDesk website to see if there is a "hotfix" for Revit 2009 that addresses the particular problem. There was something similar for vanilla AutoCAD 2008.
what version did you download, as revit architecture is on WU 3.
thanks. downloading the hotfix fixed the problem
You're welcomed. Another satisfied customer.:) Y'all come back now, ya hear?
