I'm having an issue with a few of my custom tools that I have been using with previous versions of autocad. I'm now using 2009 and I'm having a problem.
in my lisp program for automating and naming PDF files I am using the filedia command set to "0" so I can automate all the entries. I also am automating the naming but for some reason in 2009 the naming box isn't being supressed.
anyone have any ideas?
Not quite sure, would the PLQUIET variable come into play?
it looks like it has something to do with the Adobe PDF writer. I have it working with the DWG To PDF.pc3 file.
the quality of the pdf is not quite as good as the Adobe PDF printer, but it's not that big a deal.
thanks for your input
OH, now I know what your looking for. There is an option in the PDF setup where you can specify a folder to pront to automatically. It is currently set to prompt each time, which is why you are getting the box. Find that and pick a folder and it will work
