wrha Posted March 6, 2014 Posted March 6, 2014 Is there any lisp or option can export contains of many layouts in separate files to separated dwg ? Quote
cwake Posted March 6, 2014 Posted March 6, 2014 layouts in separate files to separated dwg ? I'm a little confused if the original layouts are in one file and need to be separated or in more than one file and need to be collated into one. If the former, then do what Mircea suggests. If the latter, you can copy a layout from another drawing using right click on the layout tab, "from template", select a dwg file instead of a dwt. Quote
wrha Posted March 6, 2014 Author Posted March 6, 2014 Thanks alot but what i looking is like export many layouts in new dwg i mean separated layout to separated dwg Quote
MSasu Posted March 6, 2014 Posted March 6, 2014 At first I thought that I understood your query, but after Cwake's post I realized that unfortunately isn't very clear. I'm still not sure what to understand. Please clarify, which of the diagrams below is true: Quote
wrha Posted March 6, 2014 Author Posted March 6, 2014 many layouts in separated files export to model space in separated file (like export option in autocad but for many layout) because i have huge no. of separated shop drawings i need extract the lay out with no xref Quote
SLW210 Posted March 7, 2014 Posted March 7, 2014 You need something like Export Layout to Model? Are you using AutoCAD 2007? Quote
bin007 Posted April 11, 2014 Posted April 11, 2014 I have the answere: in Layout Tab, type the command "exp". So simple Quote
mostafa badran Posted April 11, 2014 Posted April 11, 2014 Is there any lisp or option can export contains of many layouts in separate files to separated dwg ? try this. http://www.jtbworld.com/lisp/layoutstodwgs.htm HTH mostafa Quote
