surajshenoy91 Posted March 6, 2014 Posted March 6, 2014 I have a AutoCAD plan with roughly 1000 points . I want to display a sl. number along side the respective points and then generate A excel file with point number and their co ordinates. I am very new to AutoCAD. Can anyone give me detailed procedure how to do this?? Thanks in advance Quote
MSasu Posted March 6, 2014 Posted March 6, 2014 I noticed many times discussions on this matter, so a search on the Forum for "points numbering" should give you plenty of options; an AutoLISP routine that will give you the expecting result may be later easily adapted to export in CSV (for Excel) format. May want also to take a look to the tools Lee Mac is kindly offering. Quote
BIGAL Posted March 6, 2014 Posted March 6, 2014 Give this a go expects a text style of pick pt, default ht =0 not preset (defun pt2txt ( / ss x y z lineans) (setq ss (ssget "x" (list (cons 0 "Point")))) (setq fout (open "C:/temp/pt2txt.csv" "w")) (setq I 0) (repeat (sslength ss) (setq pt (assoc 10 (entget (ssname ss I)))) (setq x (nth 1 pt)) (setq y (nth 2 pt)) (setq z (nth 3 pt)) (setq lineans (strcat (rtos (+ I 1) 2 0) "," (rtos x 2 3) "," (rtos y 2 3) "," (rtos z 2 3))) (princ lineans) (command "text" (list x y z ) 2.5 0 lineans ) ;pt x y z ;(command "text" (list x y z ) 2.5 0 (rtos I 2 0) ) ; pt numb only (write-line lineans fout) (setq I (+ I 1)) ) ; repeat (close fout) (princ) ) (pt2txt) Quote
