I concur -- I've tried all manner of plotting a DWG to a PDF and found that the DWG To PDF.pc3 gives the smallest file size with consistently accurate output.
I've found that as long as you have the DWG To PDF.pc3 Custom Properties configured to "capture all the fonts" and plot them as geometry, all the issues of plotting a DWG to PDF that contain Arial or other True Type Fonts turning garbled and unreadable completely goes away.
What I'd REALLY like to see is a smoother relationship with PDF underlays .... they can be clunky to work with and plot to paper or PDF out like lo-res garbage sometimes -- very touchy feature to encourage less-than-power users to adopt comfortably when so much tweaking is necessary to overcome graphic plot settings conflicts.
  • 2 weeks later...
  • Replies 28
  • ReMark
    6
  • tzframpton
    3
  • rkent
    3
  • SEANT
    2
I have personally never had a problem with the built in pdf printer in AutoCAD. How can i get my hands on the pre-release version of AutoCAD 2015? I handle most of the software upgrading and testing for my company.
@jland504 -
I'm not sure if this is the same thing, but becoming a Beta tester for Autodesk will give you pre-release access to play around with (and give feedback on) the software before it is officially released.
It's actually kind of fun - hopefully you will get the chance to test drive 2016! :D
https://beta.autodesk.com/oid/login.html?msg=&ref=
  T-Lo said:
@jland504 -
Thanks for the help!
I fully agree with that.
Now, pre 2010 release? Yes, the built-in PDF driver was garbage. It made terrible quality, huge PDFs. We used AcroPlot back then.
But 2010 release and later..... we've been able to drop AcroPlot and use the built in driver with no problems.
Every time I try and use it, I get the following error every time:
 Job: - Error(s) Did Not Plot
Job ID: 8
Sheet set name:
Date and time started: 3/20/2014 10:05:44 AM
Date and time completed: 3/20/2014 10:05:44 AM
UserID: athompson
Profile ID: <<C3D_Imperial>>
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Number of warnings: 0
Sheet: G59.006-RP-P1-1 - Error(s) Did Not Plot
File: **file path removed by me**
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
ERROR: Device not found
Job: - Plotted
Job ID: 7
Sheet set name:
Date and time started: 3/20/2014 10:00:36 AM
Date and time completed: 3/20/2014 10:00:37 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 1
Number of errors: 0
Sheet: - Plotted
File: C:\TEMP\08152A12 REV 8-12-13.dwg
Category name:
Page setup:
Device name: \\MB-PRN\HP LaserJet 5200 PS
Plot file path:
Paper size: 11x17
Job: - Plotted
Job ID: 6
Sheet set name:
Date and time started: 3/20/2014 9:54:36 AM
Date and time completed: 3/20/2014 9:54:42 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 1
Number of errors: 0
Sheet: - Plotted
File: C:\Projects\962.009\Workfiles\survey\962.009-AB-COLUMNS.dwg
Category name:
Page setup: 18X24
Device name: Adobe PDFaaaaaaaaa.pc3
Plot file path:
Paper size: Previous paper size (24.00 x 18.00 inches)
Job: - Plotted
Job ID: 5
Sheet set name:
Date and time started: 3/20/2014 9:54:24 AM
Date and time completed: 3/20/2014 9:54:35 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 1
Number of errors: 0
Sheet: - Plotted
Category name:
Page setup: 18X24
Plot file path:
Job ID: 4
Sheet set name:
Date and time started: 3/20/2014 9:54:01 AM
Date and time completed: 3/20/2014 9:54:02 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Sheet: 962.009-AB-COLUMNS-1 - Error(s) Did Not Plot
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
Job ID: 3
Sheet set name:
Date and time started: 3/20/2014 9:53:15 AM
Date and time completed: 3/20/2014 9:53:25 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 0
Number of errors: 1
Category name:
Page setup: 18X24
Device name:
Plot file path:
Paper size:
ERROR: Page setup not found
Job: - Plotted
Job ID: 2
Sheet set name:
Date and time started: 3/20/2014 9:27:31 AM
Date and time completed: 3/20/2014 9:27:37 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 1
Number of errors: 0
Sheet: - Plotted
Category name:
Page setup:
Device name: \\mb-prn\HPDesignJet4000DN
Plot file path:
Paper size: Oversize: Arch C (landscape)
Job: - Plotted
Job ID: 1
Sheet set name:
Date and time started: 3/20/2014 9:27:23 AM
Date and time completed: 3/20/2014 9:27:29 AM
UserID: athompson
Total sheets: 1
Sheets plotted: 1
Number of errors: 0
Sheet: - Plotted
Category name:
Page setup:
Plot file path:
It does seem much faster and smoother running. They have worked on the display and arcs and non-ortho lines looks smooth instead of stepped. That alone is worth the upgrade. Not sure there is much else new in the way of new tools, etc.
The dark style is also in 2014, just a toggle in the options, display tab.
  ReMark said:
I can't wait to see what new bugs they introduced
Bug No1: missing horizontal scroll bar :x
  issammm said:
I saw this youtube video, about new features of autoCAD 2015:
Says private link now, may have been asked to take it down by the you tube police.
