Guest Trekiez Posted February 26, 2014 Share Posted February 26, 2014 (edited) Hi, I've had this ongoing problem where, when Clipboard>Copy(ing) contour lines and triangles, there always seems to be one contour line with a ridiculous elevation. i.e if all my contour lines were around an RL of 60-70 (as an example, this happens regardless of the spread or elevation of the RLs), there would be one line that is around +4000000, which is an extreme height. The problem I am having with this is that I can't trim or extend the line to meet the Title Boundaries of the property I am contouring. I export the Contour file (Created in AutoCAD Civil 3D 2010) to a 2010 format, then open this exported file and Clipboard>Copy the contour lines and triangles from the file. I then Clipboard>Paste To Original Coordinates. This problem does not really affect my drafting, it has just become an annoyance after months of having to click and drag several poitns back to the title boundary. Thanks in advance and feel free to ask any questions if I have not been clear! ~ Jake Edited February 26, 2014 by Trekiez Quote Link to comment Share on other sites More sharing options...
Guest Trekiez Posted February 26, 2014 Share Posted February 26, 2014 I forgot to mention, I am pasting these contours into an AutoCAD 2014 .DWG File Quote Link to comment Share on other sites More sharing options...
Guest Trekiez Posted February 26, 2014 Share Posted February 26, 2014 Another thing I should have added before - Projmode is set to 2 and Edgemode is set to 1, so that isn't the problem. Quote Link to comment Share on other sites More sharing options...
Organic Posted February 26, 2014 Share Posted February 26, 2014 When you paste the contours are you using 'paste to original coordinates'? Quote Link to comment Share on other sites More sharing options...
Guest Trekiez Posted February 26, 2014 Share Posted February 26, 2014 Yes I use Clipboard ==> Paste to Original Co-ordinates to do this. Quote Link to comment Share on other sites More sharing options...
