Hi,
When using the Export function on the command line is there a way to type the destination in rather than having the save dialog pop up?
Thanks.
If you have the system variable FILEDIA set to 0, then Export works on the command line.
Just remember to set it back to 1, otherwise no file dialogue boxes come up.
Or do like I do. Keep FILEDIA set to 0 and use ~ to bring the dialog box only when I need it. -David
