highflybird Posted February 25, 2014 Posted February 25, 2014 (defun c:tt( / en en1 pt p1 p2 p3 p4 dist) (setvar 'osmode 0) (setq dist (getdist (strcat "Enter the offset distance:<" (rtos (getvar "OFFSETDIST")) ">"))) (if (null dist) (setq dist (getvar "offsetdist")) (setvar "offsetdist" dist) ) (while (setq en (car(entsel"\nPlease select object:"))) (command "offset" dist en pause "") (setq en1 (entlast)) (setq p1(vlax-curve-getstartpoint en) p2(vlax-curve-getendpoint en) p3(vlax-curve-getstartpoint en1) p4(vlax-curve-getendpoint en1)) (command ".line" p1 p3 "" ".line" p2 p4 "")) (setvar 'osmode 4133) (princ) ) This code can't Multiple choice ,For cricle, rectangular,Closed polyline support is not perfect. Quote
Lee Mac Posted February 25, 2014 Posted February 25, 2014 This program could be modified to suit: http://www.cadtutor.net/forum/showthread.php?75999&p=512946&viewfull=1#post512946 Quote
liuhaixin88 Posted February 26, 2014 Posted February 26, 2014 This program could be modified to suit: http://www.cadtutor.net/forum/showthread.php?75999&p=512946&viewfull=1#post512946 Thanks lee, I will look carefully! Quote
highflybird Posted February 27, 2014 Author Posted February 27, 2014 THS,Lee,I test, Find It's not support "circle" and "arc", And, for closed polyline have a problem. Quote
Lee Mac Posted February 27, 2014 Posted February 27, 2014 THS,Lee,I test, Find It's not support "circle" and "arc" Yes, the program only supports polylines. And, for closed polyline have a problem. Please upload a drawing for which the program fails. Quote
