pqphillips Posted February 24, 2014 Posted February 24, 2014 Is it considered safe to delete a database object (specifically the "LR" (Latching Relay) database object) out of the default database? Will this negatively affect the database or cause it to no longer function properly? The reason I ask is because we don't use Latching Relays, but we do use "LR" as tag information for Line Reactors. Quote
JohnS Posted June 10, 2015 Posted June 10, 2015 You can delete the parts in "LR" and use table LR for your line reactors, in my case I left the Latching relays there and just added my line reactors. To answer your question you can delete tables in the default mdb data base and it won't hurt anything, same for adding tables. Quote
