James Connolly Posted February 24, 2014 Posted February 24, 2014 hi , i have a problem i have made a 3D model i have put textures on it looks great ,however you can still see some of the white 2D lines on the 3D model. I try to delete them but it doesn't recognize the line even though i can clearly see it. Is there any way to turn them off. Quote
ReMark Posted February 24, 2014 Posted February 24, 2014 This question sounds vaguely familiar. Without seeing an image or a drawing I say it could be one of these three system variables: ISOLINES FACTRES DISHSILH Quote
ReMark Posted February 24, 2014 Posted February 24, 2014 Dug this out of the dust bin. AutoCAD settings that affect 3D output. DISPSILH – Display Silhouette This setting affects the results of the Hide command. A setting of 0 displays tessellation lines. A setting of 1 suppresses tessellation lines. FACETRES – Rendered Object Smoothness This setting affects both rendering and hide results. The default setting is 0.5. The max setting is 10. A lower setting results in a quicker render time but rounded edges will appear as a series of straight segments. A higher setting results in a longer render time but rounded edges will appear much smoother. ISOLINES – Contour lines per surface This setting affects the wireframe view but not the Hide or Render commands. Settings can range from 0 to 2047. The default setting is 4. SPLINESEGS – Segments in a Polyline Curve This setting controls the number of segments in a polyline curve. The settings range from 0 to 32767 with the default being 8. The higher the setting the smoother the appearance is of a rendered curve. Quote
