File Tab missing from Options Dialog?
Having an issue with the Options Dialog Box. I am running AutoCAD 2014 on Windows 8.1. When I open my options dialog box, the first tab is "Open and Save" instead of the Files tab. Any idea how to get this back or what is causing it to go away?
Please notice that there is a pair of arrows on top-right side of the dialog (at the same level with tab labels); those will allow you to show the tabs that were not visible due to the limited width of the dialog.
DUH! Thank you. I can't believe I went as far as to post that. Sorry for the lameness!
Don't worry, Jayhawk261! Like the small arrow button to extend the PRINT command's dialog, this solution isn't the most intuitive one. What finally matter is that your issue is solved!
