kratki spoj Posted February 14, 2014 Share Posted February 14, 2014 Hi, I'm wondering if there's a lisp that could increment numbers in selected text. For example : 1/1,1/2,1/3...to 1/2,1/3,1/4... So, program should select text and then increment or decrement prefix or sufix. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 15, 2014 Share Posted February 15, 2014 Just a solution take the text read each character till you find the "/" then read the rest use rtos to make back into a number add 1 the convert to a string and add start start string. As a start search for a lisp "find character" the most common is for CSV. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 15, 2014 Share Posted February 15, 2014 Try this program: Text Increment Quote Link to comment Share on other sites More sharing options...
kratki spoj Posted February 17, 2014 Author Share Posted February 17, 2014 Thank's for replies. @ Lee Mac Text increment selects one element at a time. That takes time if you have numbers from one to a hundred or so. Is there a way to select al of the elements at once ? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 17, 2014 Share Posted February 17, 2014 (edited) kratki spoj said: Text increment selects one element at a time. That takes time if you have numbers from one to a hundred or so. Is there a way to select al of the elements at once ? Try this quick mod: ;; Text Increment - Lee Mac ;; Increments numerical data found in a selection of Text or MText ;; objects by a value specified by the user. (defun c:txtinc ( / e i l s x ) (if (null *inc*) (setq *inc* 1.0) ) (if (setq i (getreal (strcat "\nSpecify Increment <" (rtos *inc* 2) ">: "))) (setq *inc* i) ) (if (equal 0.0 (rem *inc* 1) 1e-8) (setq *inc* (fix *inc*)) ) (if (setq s (ssget "_:L" '((0 . "TEXT,MTEXT") (1 . "*#*")))) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) x (assoc 1 e) ) (entmod (subst (cons 1 (apply 'strcat (mapcar (function (lambda ( x ) (if (and (= 'int (type x)) (= 'int (type *inc*))) (itoa (+ x *inc*)) (if (member (type x) '(int real)) (rtos (+ x *inc*) 2) x ) ) ) ) (LM:splitstring (cdr x)) ) ) ) x e ) ) ) ) (princ) ) ;; Split String - Lee Mac ;; Splits a string into a list of text and numbers (defun LM:splitstring ( s ) ( (lambda ( l ) (read (strcat "(" (vl-list->string (apply 'append (mapcar (function (lambda ( a b c ) (cond ( (= 92 b) (list 32 34 92 b 34 32) ) ( (or (< 47 b 58) (and (= 45 b) (< 47 c 58) (not (< 47 a 58))) (and (= 46 b) (< 47 a 58) (< 47 c 58)) ) (list b) ) ( (list 32 34 b 34 32)) ) ) ) (cons nil l) l (append (cdr l) (list nil)) ) ) ) ")" ) ) ) (vl-string->list s) ) ) (princ) Edited December 19, 2018 by Lee Mac Quote Link to comment Share on other sites More sharing options...
kratki spoj Posted February 18, 2014 Author Share Posted February 18, 2014 Thank's Lee. That's what I was looking for. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 18, 2014 Share Posted February 18, 2014 You're welcome! Quote Link to comment Share on other sites More sharing options...
bababarghi Posted February 22, 2014 Share Posted February 22, 2014 Not sure if it may contribute to solution or not. Following trick is highly dependant to your case: I usually delete all text entities which I need to increment the numercial part of them. Copy a single pattern to proper location and then leverage the 'Find&Replace' option of AutoNumber (ExpressTools). In above scenario, you just need to copy '1/x' to all desired place. In find&replace, type 'x'. As I said, it might not be always feasible to everyone but I use it a lot. Hi,I'm wondering if there's a lisp that could increment numbers in selected text. For example : 1/1,1/2,1/3...to 1/2,1/3,1/4... So, program should select text and then increment or decrement prefix or sufix. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
