Well I'm ever so slowly making progress with vb.net.
Here's the latest issue I'm having:
I have a program that prompts for two endpoints, then inserts a line based on those endpoints. Once the line is inserted the program then also inserts a block at the centerpoint of the line.
The program works just fine when the UCS is in it's normal position (aligned with the WCS?).
However, if I move the UCS in any way (rotate 15 degrees for instance), the lines and blocks end up inserted in odd places on the drawing. Their sizes and relative orientations are correct, but their overal insertion points are not.
I'd post some code, but it's not very straight forward looking. However, I'm using standard methods for getting user input fromt the editor and inserting the line and block into the active drawing database.
My best guess is that when the user enters the two points, AutoCAD is converting those points to some WCS coordinate that isn't getting translated back to the current UCS when the line and block is inserted. Unfortunately I don't know how to fix this (assuming that is the problem).
Any ideas about what might be causing this?
Yes, that is a translation issue and requires steps similar to those needed with VBA.
Below is a vb.net demo. Like most demo code, error checking should be modified to whatever level required.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class STSCCommands
   <CommandMethod("BTM")> _
   Public Sub Tester()
       Dim strBlkName As String = "Arrow_E" 'change to suit
       Dim strBlkPath As String = "C:\STCustomCommon\Arrow_E.dwg" 'change to suit
       If Block2Mid(strBlkName, strBlkPath) Then
           Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbCr & "Block insertion successful.")
       End If
   End Sub
   Public Function Block2Mid(ByVal strBlkName As String, ByVal strBlkPath As String) As Boolean
       Dim db As Database = HostApplicationServices.WorkingDatabase
       Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
       Dim ucsMat As Matrix3d = ed.CurrentUserCoordinateSystem
       Dim bt As BlockTable
       Dim btr As BlockTableRecord
       Dim btrSpace As BlockTableRecord
       Dim entBref As BlockReference
       Dim ppo As PromptPointOptions = New PromptPointOptions("Select first point: ")
       ppo.AllowNone = False
       ppo.AllowArbitraryInput = False
       Dim ppr As PromptPointResult = ed.GetPoint(ppo)
       If ppr.Status = PromptStatus.Cancel Or ppr.Status = PromptStatus.Error Then Exit Function
       Dim p3d1 As Point3d = ppr.Value
       ppo.UseBasePoint = True
       ppo.BasePoint = p3d1
       ppo.Message = vbCr & "Select second point: "
       ppr = ed.GetPoint(ppo)
       Dim p3d2 As Point3d = ppr.Value
       Dim v3d1 As Vector3d = p3d1.GetAsVector()
       Dim v3d2 As Vector3d = p3d2.GetAsVector()
       v3d2 = v3d2 - v3d1
       v3d2 = v3d1 + (v3d2 / 2.0)
       Dim midPt As Point3d = New Point3d(v3d2.ToArray())
       p3d1 = p3d1.TransformBy(ucsMat)
       p3d2 = p3d2.TransformBy(ucsMat)
       midPt = midPt.TransformBy(ucsMat)
       Dim entLine As Line = New Line(p3d1, p3d2)
       Using tr As Transaction = db.TransactionManager.StartTransaction()
           bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
           If bt.Has(strBlkName) Then
               btr = tr.GetObject(bt.Item(strBlkName), OpenMode.ForRead)
           Else
               btr = RtrvBlk(strBlkName, strBlkPath, ed, db)
               If btr = Nothing Then
                   Block2Mid = False
                   Exit Function
               End If
           End If
           Try
               btrSpace = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
               btrSpace.AppendEntity(entLine)
               entBref = New BlockReference(midPt, btr.ObjectId)
               entBref.Normal = ucsMat.CoordinateSystem3d.Zaxis
               entBref.Position = midPt 'requires re-positioning after Normal mod
               btrSpace.AppendEntity(entBref)
               tr.AddNewlyCreatedDBObject(entLine, True)
               tr.AddNewlyCreatedDBObject(entBref, True)
               tr.Commit()
           Catch ex As System.Exception
               ed.WriteMessage(ex.Message)
               Block2Mid = False
           End Try
           Block2Mid = True
       End Using
   End Function
   Public Function RtrvBlk(ByVal strBlkName As String, ByVal strBlkPath As String, ByRef ed As Editor, ByRef db As Database) As BlockTableRecord
       Dim btr As BlockTableRecord = Nothing
       Dim id As ObjectId
       Dim actDoc As Document = Application.DocumentManager.MdiActiveDocument
           Try
               bt = tr.GetObject(db.BlockTableId, OpenMode.ForWrite)
               Using importDb As Database = New Database(False, False)
                   Try
                       importDb.ReadDwgFile(strBlkPath, IO.FileShare.Read, True, "")
                       id = db.Insert(strBlkPath, importDb, True)
                       btr = tr.GetObject(id, OpenMode.ForWrite)
                       btr.Name = strBlkName
                       btr.DowngradeOpen()
                       Return Nothing
                       Exit Function
                   Finally
                       importDb.Dispose()
                   End Try
               End Using
               tr.Commit()
           End Try
       End Using
       Return btr
   End Function
End Class
Ok, so it sounds like all point input is done in terms of the WCS and is then translated to the current UCS using a transofmation matrix.
Thanks for the sample code. Did you write it or did you get it from ome other resource?
- Joe
Generally, everything I post is self written. I wouldn’t necessarily take credit for a fairly generic routine such as this (when I say generic, I mean one that has probably been written numerous times before, not necessarily one that was easy to write). This generic quality (because the need for this task is quite common) means that useful snippets are quite plentiful and I was able to borrow – heh hem – portions here and there.
Most of the UCS stuff was similar enough to VBA that previous experience was very helpful.
Now that I’ve admitted ownership to a good portion of this ‘compilation’, I expect the real pros to stop by and tell what I really should have done to make it better. :)
Hah, good enough for me.
As you can tell, I'm still in the thick of trying to figure out the ins and outs of dealing with AutoCAD behind the scenes. It can be a bit daunting at times trying to remember how things are structured.
I'm just now starting to learn about transformations, it's great stuff to know.
Thanks for your help.
Despite the enormity of the .NET api, transformations are an area where the process has been simplified; at least compared to VBA. Once located, a lot of .NET tools are readily available.
You're welcome.
