uzixs911 Posted February 12, 2014 Posted February 12, 2014 hi i am using max 2014 . i make a file in 2009 max . now when i open the file in max 2014 and render it in v ray all the objects appear white.all the texture images dnt appear well i asked my friend he told me there is a material update option in max. ..i cant find it please help me i need a urgent answer form some one . Quote
uzixs911 Posted February 12, 2014 Author Posted February 12, 2014 futher more i am using vray and have used metal ray wall paints in old version Quote
Cad64 Posted February 12, 2014 Posted February 12, 2014 If you're rendering with Mental Ray, then you use Mental Ray materials. If you're rendering with Vray, then you use Vray materials. You can't mix and match. If you created your scene file in 2009 with Mental Ray materials, you will have to open the scene in 2014 and apply new Vray materials. Quote
uzixs911 Posted February 12, 2014 Author Posted February 12, 2014 ok and is there any material update option of same Plugin like if i want to render matel ray to matel ray from 09 to 2014 version.because my materials appear white even if i render metal ray in 2014 Quote
