uzixs911 Posted February 11, 2014 Posted February 11, 2014 please kindly suggest me graphics card . my currently pc status is 4 gb ram core i 5 now i am increasing ram to 12 gb and graphics card also .please suggest me aout graphics card i.e. one gb or 2 gb and also suggest company . i think geforce is better . but professional views are welcome . i wil be using vray max 2014 and cad 2013 Quote
uzixs911 Posted February 11, 2014 Author Posted February 11, 2014 anybody please help me need some help in graphics card selection for vray work. i have posted into 3d max general forum but no reply .. please help me i need a graphics card for vray my pc specs are 12 gb ram with core i5. which company card is good for vray work Quote
Cad64 Posted February 11, 2014 Posted February 11, 2014 I have merged your two threads together. Please don't post the same question multiple times. If someone has an answer for you, they will post it, regardless of which area of the forum you post your question. Are you planning on using the GPU for rendering? If not, then it shouldn't really matter what video card you choose. Any mid to high end video card should work fine. I won't tell you which card to choose, but I will tell you that I have always used Geforce cards and never had any problems. You said you are increasing your RAM from 4GB to 12GB? I assume you're running a 64 bit operating system? Quote
spittle Posted February 11, 2014 Posted February 11, 2014 I use a GTX580 at home which is good. I use a GTX 570 at work which is also good and that's working on some huge scenes. The 580 is better though. Quote
uzixs911 Posted February 11, 2014 Author Posted February 11, 2014 ok thanks ..yes i am now using 64 bit operating system.. Quote
uzixs911 Posted February 11, 2014 Author Posted February 11, 2014 well i have like 800-1000 dollars Quote
ReMark Posted February 11, 2014 Posted February 11, 2014 You might look at the nVidia Quadro K4000. Should you want to follow nVidia's recommendation for users of 3ds Max then you are going to need a fatter wallet. http://www.nvidia.com/content/quadro/autodesk-suites/pdf/3dsMax-Solution-Overview-Nov13.pdf Quote
tzframpton Posted February 11, 2014 Posted February 11, 2014 GTX-770 with 4GB RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125462 Stout card for less than $400. Will do anything and everything you'll need. Quote
Mike_Taylor Posted February 11, 2014 Posted February 11, 2014 tzframpton said: GTX-770 with 4GB RAM:http://www.newegg.com/Product/Product.aspx?Item=N82E16814125462 Stout card for less than $400. Will do anything and everything you'll need. This I agree with, I just picked up 2 for my build at home. Other manufacturers make slightly overclocked versions with some after mark cooling on them (EVGA and Zotac for exqample) that may give a fairly good performance boost for the xtra money you may pay. Quote
pattyandme Posted April 18, 2015 Posted April 18, 2015 Gaming Cards or GeForce cards when compared to workstation cards or Quadro will not perform as well. When rendering or working in 3d model with realistic view or creation of walk around or fly by views in 3d model with rendering of the image plates will be fast with the work station cards because they are designed for that. Quadro fx cards are designed for video editing and rendering at a greater detail and speed than a gaming card which is looking for performance over substance. FPS vs Detail in the frame. Quote
Cad64 Posted April 18, 2015 Posted April 18, 2015 For my money, I'll stick with GeForce cards. They have always worked fine for me and I simply can't justify the cost of a Quadro. But for those who are interested, here's a side by side comparison of the GeForce GTX 580 vs. Quadro 5000 from a few years ago: http://www.nyc3d.org/3dwp2/geforce-gtx-580-vs-quadro-5000/ Quote
hunterslash Posted December 24, 2015 Posted December 24, 2015 GIGABYTE GV-N770OC-4GD GeForce GTX 770 a good card Quote
Andrew1979 Posted December 31, 2015 Posted December 31, 2015 To be honest from experience, even a $35 video card is usable depending on what you want from it. The Quadro cards are designed for the CAD industry but any card can be used. If you are planning on using Vray-RT, then the video card will be important as Vray-RT uses the graphics card. When doing final renders with Vray in 3D studio max though, the graphics card does not render it is the CPU that does all the work so a secondary computer is better in this regard to use as Distributed Rendering in Vray. This is what is called a render farm when multiple computers are used to render one image using the power of all computers at the same time via Distributed Rendering. Quote
