Hi,
My request is really simple.
The block align to a polyline and reverse the arrow. (correct)
I'm trying to lock the attribute to doesn't reverse with the block (lock)
I couldn't do that.
Anybody can help me out please?
block test.dwg
I just wanted to my block aligned according to a polyline and give me a option to reverse the arrow (just the arrow, the attribute doesn't change).
Thank in advance.
Hi this sort of does it but needs two separate operations. I'm not sure if the align on it's own can be stopped from inverting the attribute.
align.dwg
Thank you very much Steven,
The Dinamic Block worked like a charm, just like I expected to.:D
I've tried used flip action to reverse arrow's direction, but the attritube also reversed.
Very smart way to create the block.
Many Thank you.
Kind Regards!
