Apparent intersection between two objects
That's good advice Hipper013. But if you do not have AutoCAD Civil 3D, what can you do?
I started working on this program in January 2014.
So far, I have managed to create the 3D TIN , do sections , to draw contours and calculate volumes.
And what is more interesting, I can constrain TIN by 3D objects.
And still not finished the year.
To intersect an object 3DMESH with a linear object, you must first put z = 0 for all TIN and then reset the coordinates.
(setq lisCooTIN (vla-Get-Coordinates myTinV)  )
(function "put z = 0 for all TIN")
(while (setq lisCooI (vla-IntersectWith myTinV objLin acExtendNone))
(vla-Put-Coordinates myTinV lisCooTIN )
Edited by Costinbos77
  • Replies 20
  • Costinbos77
    9
  • ymg3
    5
  • bullah
    4
  • hanhphuc
    1
Posted Images
