HI everyone,
I am facing a problem when i am converting dwg to dxf.
actually i am drawing some plates by lisp routine and the same thing has to save as to dxf. Without saving to the dwg file.
Once if i saved my dwg, then i can do that. But i need without saving.
Use the command Wblock to have the selected objects to a new drawing then dxfout them .
You can use the 'Select Objects' option of the DXFOUT command to export only the required objects to a separate DXF file.
Thanks Mr Lee
i have seen some where your post, if we use wblock just it will compress but that wont give exact dxf.
So I used dxfout.
its working nice and our machine also reading the dxf file.
