ali888 Posted December 15, 2006 Posted December 15, 2006 Hi, I was wondering if anyone might be able to help me here. I was trying to write DXF code for drawing an Ellipse. So here is what i did. I got the code by drawing an ellipse and then saved it as DXF. So I started off with a blank page. I began writing it as follows 0 SECTION 2 ENTITIES 0 ELLIPSE 8 0 10 629.4185943561319 20 564.6465625762273 30 0.0 11 0.0 21 -182.0310286257299 31 0.0 210 0.0 220 0.0 230 1.0 40 0.3696612519921331 41 0.0 42 6.283185307179586 0 ENDSEC 0 EOF I got an error while opening this DXF drawing. it said that "Undefined group code 10 for object on line 10" I thought 10 denotes the X-Coordinates. Why is the autocad not able to define it? Thank you in advance Quote
LSR Posted December 15, 2006 Posted December 15, 2006 Hi, I got an error while opening this DXF drawing. it said that "Undefined group code 10 for object on line 10" I thought 10 denotes the X-Coordinates. Why is the autocad not able to define it? Thank you in advance Sorry, I take back my comments. Quote
keberle Posted October 27, 2008 Posted October 27, 2008 have you determined the cause fo the error? I have the same problem but cannot figure out the cause. Quote
