Hei.
Im looking for a routine that replaces selected blocks. In addition i want the replaced blocks to have the same attributevalue as the old blocks. The blocks have the same attributes.
I have found many routines that replaces selected blocks, but they all overwrites the original attribute values.
Why wouldn't you just reimport and redefine the block?
The blocks are a part of a schematic. I only want to change selected instanses of blocks and the attributes should not be overwritten.
I have made a video to better illustrate what i mean: https://dl.dropboxusercontent.com/u/18606927/Replace.wmv
I want the blocks to remenber its attributes, so I dont have to change it back.
Can you post an example of the block to be replaced (with the attributes you want to keep) and the block that will replace it. There is too much info in that video to see what is going on.
Hei.
I am achieving the same goal you are persuing simply by following these steps:
- Select all your desired blocks to be replaced;
- Type ATTOUT ('export attributes' feature of Express Tools) to export selected blocks' attributes only;
- Try to load this LISP (credit goes to alanjt) and replace your selected blocks. The attributes may disappear (don't panic)
FYI. As mentioned by alanjt, you need this function as well.
- [optional:] if you feel any difference in attribute order or prompt, you can simply edit the text file containing previously exported attributes.
- Type ATTIN ('import attributes' feature of Express Tools) and bring your attributes back.
It works fine for me 8)
Edited by bababarghi
Typos
Although I have nothing to test this with, it should work:
[b][color=BLACK]([/color][/b]defun c:rpb [b][color=FUCHSIA]([/color][/b]/ rb ss i en ed[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]or [b][color=MAROON]([/color][/b]not rb[b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]snvalid rb[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]or [b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] rb[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
                [b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]findfile [b][color=RED]([/color][/b]strcat rb [color=#2f4f4f]".DWG"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq rb [b][color=MAROON]([/color][/b]strcase [b][color=GREEN]([/color][/b]getstring [color=#2f4f4f]"\nReplacement BLOCK Name:   "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] rb[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]progn
       [b][color=MAROON]([/color][/b]command [color=#2f4f4f]"_.INSERT"[/color] rb[b][color=MAROON])[/color][/b]
       [b][color=MAROON]([/color][/b]command[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]/= [b][color=MAROON]([/color][/b]logand [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 70 [b][color=RED]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] rb[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] 2[b][color=MAROON])[/color][/b] 2[b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]alert [b][color=MAROON]([/color][/b]strcat [color=#2f4f4f]"Replacement BLOCK "[/color] rb [color=#2f4f4f]" Must Have Attributes"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
       [b][color=MAROON]([/color][/b]princ [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"\nSelect INSERTs To Replace With "[/color] rb[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
       [b][color=MAROON]([/color][/b]while [b][color=GREEN]([/color][/b]setq ss [b][color=BLUE]([/color][/b]ssget [b][color=RED]([/color][/b]list [b][color=PURPLE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=PURPLE])[/color][/b][b][color=PURPLE]([/color][/b]cons 66 1[b][color=PURPLE])[/color][/b]
                                    [b][color=PURPLE]([/color][/b]cons 2 [b][color=TEAL]([/color][/b]strcat [color=#2f4f4f]"~"[/color] rb[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
              [b][color=GREEN]([/color][/b]setq i 0[b][color=GREEN])[/color][/b]
              [b][color=GREEN]([/color][/b]while [b][color=BLUE]([/color][/b]setq en [b][color=RED]([/color][/b]ssname ss i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                     [b][color=BLUE]([/color][/b]setq ed [b][color=RED]([/color][/b]entget en[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                     [b][color=BLUE]([/color][/b]entmod [b][color=RED]([/color][/b]subst [b][color=PURPLE]([/color][/b]cons 2 rb[b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]assoc 2 ed[b][color=PURPLE])[/color][/b] ed[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
                     [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1+ i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
[b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
Edited by David Bethel
David, don't you think following highlighted lines are in contradict? :huh:
(while (or (not rb)
            (not (snvalid rb))
            (or ([color="red"]not (tblsearch "BLOCK" rb[/color]))
                (not (findfile (strcat rb ".DWG")))))
        (setq rb (strcase (getstring "\nReplacement BLOCK Name:   "))))
 [color="red"](if (not (tblsearch "BLOCK" rb))
       (command "_.INSERT" rb)
       (command)
 )[/color]
-David
If the replacement block is an external dwg reference, then it must be INSERTed into the current drawing to record the definition into the BLOCK table. Otherwise, the (entmod) call will fail. -David
