Guys,
What is the solution if I want to convert all entities on
Layer Pen35 (Colour=ByLayer) to Layer Base (Colour=Yellow)?
Both Laytrans and LayMrg (and even this) won't allow me to pick target layer's colour.
I need to apply several of such layer mappings e.g.
- Pen25 --> Base (White)
- Pen35 --> Base (Yellow)
- Pen50 --> Base (Red)
etc.
Additionally, I can't use Quick Select because of numerous nested blocks in the drawing. Above question would be addressed if I could select objects in nested blocks with Quick Select.
  • 1 month later...
Just in case if anyone else had a same situation, here is what I did:
There is LSP in ToolPac called Hardcode Color which basically assigns object colour from their layer colour (hardcode). All I did afterwards, was to put all my objects onto Base layer. :)
P.S: if anyone has a similar routine to assign hardcoded colours on objects (based on their layer colour), please let me know.
What about using FILTER then Properties
Not a chance. As I said in my first post, there are several multi level nested blocks which caused the whole grief initially.
You may have to do a by object type conversion and run a couple of passes, in particular one for blocks, checkout WWW.Lee-mac.com for a change all block properties.
Sadly, I am not following on following two parts:
... by object type conversion ...
:huh:
Does Lee have a lsp for that?! :unsure:
