ekolman2003 Posted February 4, 2014 Share Posted February 4, 2014 re-bar quantity lisp working dd command. firstly, u select "for example: 11f8/30" and then u select "for example: L=250 cm" lenght. u select all rebar like this. and then press enter. it will be an excel file. the lisp write all datas side by side. for example: 22f8/30 L:250 11f8/20 L:40 I want this 22f8/30 L:250 . please help. 11f8/20 L:40 1-) Statik Proje.dwg re-bar quantity.lsp Quote Link to comment Share on other sites More sharing options...
pyrzms Posted February 5, 2014 Share Posted February 5, 2014 http://www.cadtutor.net/forum/showthread.php?84023-Combine-text-strings read this thread. Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 6, 2014 Author Share Posted February 6, 2014 thanks but that lisp is different Quote Link to comment Share on other sites More sharing options...
ymg3 Posted February 17, 2014 Share Posted February 17, 2014 ekolman, Here is something that works more or less in your case. We find the bounding box of the bar text then send creates a fence selection from the center of the bb to the left of it. We sort the resulting selection set on distance from the bounding box. However you managed to have some bar with distance to the right or on top of each other. So please correct these before using. Entity that cannot be matched are highlightred with a rectangle around them. The matched entities are sent to a CSV file. No amount of Lisp will replace a well drafted drawing. The way your annotations are done, makes it difficult even for a human to figure the dimension of the bars. (defun c:test (/ dir dist en en2 ent ent2 fh fname f1 f2 foundl i j mn mx nomatch p1 p2 searchlen ss ss2) ;; File is opened in Append Mode ; (setq fname (strcat (getvar "dwgprefix") (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4 )) ".csv") fh (open fname "a")) (setq scrsize (getvar 'SCREENSIZE) ratio (/ (car scrsize) (cadr scrsize)) searchlen (* (getvar 'VIEWSIZE) ratio) ; Length of Selection Fence ; nomatch 0 ; Number of Items with no matched length ; ) ;; Selecting All Text with Character ASCII 131 ; (if (setq ss (ssget "_X" '((0 . "TEXT") (1 . "#*`ƒ#*`/##")))) (progn (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i))) ent (entget en) dir (cdr (assoc 50 ent)) ) (vla-getboundingbox (vlax-ename->vla-object en) 'mn 'mx) (setq p1 (vlax-safearray->list mn) p2 (vlax-safearray->list mx) ) ;; First point of fence is midpoint of Bar Description. ; (setq f1 (list (/ (+ (car p2) (car p1)) 2.) (/ (+ (cadr p2) (cadr p1)) 2.)) f2 (polar f1 dir searchlen) ) (if (setq ss2 (ssget "_F" (list f1 f2) '((0 . "TEXT") (1 . "L=#*")))) (progn (setq foundl nil) (repeat (setq j (sslength ss2)) (setq en2 (ssname ss2 (setq j (1- j))) ent2 (entget en2) dist (distance f1 (cdr (assoc 10 ent2))) foundl (cons (list dist (cdr (assoc 1 ent2))) foundl) ) (setq foundl (vl-sort foundl (function (lambda (a b) (< (car a) (car b)))))) (write-line (strcat (cdr (assoc 1 ent)) ", " (cadr (car foundl))) fh) ) ) ;; If we did nod not find put a rectangle around the entity. ; (progn (vl-cmdf "_RECTANGLE" p1 p2) (setq nomatch (1+ nomatch)) ) ) ) ) ) (princ (strcat "File: " fname " has been created.")) (close fh) (if (> nomatch 0) (alert (strcat (itoa nomatch) " Bars could not be matched."))) (princ) ) ymg 1 Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 17, 2014 Author Share Posted February 17, 2014 thanks a lot ymg. u are a perfect man:)) its excellent code. can we add "repair" this code like rebar.lisp? Quote Link to comment Share on other sites More sharing options...
ymg3 Posted February 17, 2014 Share Posted February 17, 2014 Ekolman, Yes you can add it. Except as I told you, there is a possibility that some annotations could be mixed up in the case where the length is not in the same direction as the bar annotations. ymg Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 17, 2014 Author Share Posted February 17, 2014 ymg how we can do rebar quantity like this=? I dont know code language sorry man. beam.dwg Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 17, 2014 Author Share Posted February 17, 2014 test code not work like this rebar text ; 2ƒ14 L=150 or 2x2ƒ12 L=200 Quote Link to comment Share on other sites More sharing options...
fixo Posted February 17, 2014 Share Posted February 17, 2014 change filter like this: (setq ss (ssget "_X" '((0 . "TEXT") (1 . "#*\\U+0130#*`/##")))) ymg beat me for it Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 18, 2014 Author Share Posted February 18, 2014 (defun c:test (/ dir dist en en2 ent ent2 fh fname f1 f2 foundl i j mn mx nomatch p1 p2 searchlen ss ss2) ;; File is opened in Append Mode ; (setq fname (strcat (getvar "dwgprefix") (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4 )) ".csv") fh (open fname "a")) (setq scrsize (getvar 'SCREENSIZE) ratio (/ (car scrsize) (cadr scrsize)) searchlen (* (getvar 'VIEWSIZE) ratio) ; Length of Selection Fence ; nomatch 0 ; Number of Items with no matched length ; ) ;; Selecting All Text with Character ASCII 131 ; (if (setq ss (ssget "_X" '((0 . "TEXT") (1 . "#*\\U+0130#*`/##")))) (progn (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i))) ent (entget en) dir (cdr (assoc 50 ent)) ) (vla-getboundingbox (vlax-ename->vla-object en) 'mn 'mx) (setq p1 (vlax-safearray->list mn) p2 (vlax-safearray->list mx) ) ;; First point of fence is midpoint of Bar Description. ; (setq f1 (list (/ (+ (car p2) (car p1)) 2.) (/ (+ (cadr p2) (cadr p1)) 2.)) f2 (polar f1 dir searchlen) ) (if (setq ss2 (ssget "_F" (list f1 f2) '((0 . "TEXT") (1 . "L=#*")))) (progn (setq foundl nil) (repeat (setq j (sslength ss2)) (setq en2 (ssname ss2 (setq j (1- j))) ent2 (entget en2) dist (distance f1 (cdr (assoc 10 ent2))) foundl (cons (list dist (cdr (assoc 1 ent2))) foundl) ) (setq foundl (vl-sort foundl (function (lambda (a b) ( (write-line (strcat (cdr (assoc 1 ent)) ", " (cadr (car foundl))) fh) ) ) ;; If we did nod not find put a rectangle around the entity. ; (progn (vl-cmdf "_RECTANGLE" p1 p2) (setq nomatch (1+ nomatch)) ) ) ) ) ) (princ (strcat "File: " fname " has been created.")) (close fh) (if (> nomatch 0) (alert (strcat (itoa nomatch) " Bars could not be matched."))) (princ) ) Quote Link to comment Share on other sites More sharing options...
ymg3 Posted February 18, 2014 Share Posted February 18, 2014 ekolman, Most of your annotations are now on top of each other. It cannot work. To be able to join the distance has to be to the left. Anyway all of this is always a plaster on a wooden leg. Your annotation should be one text entity for it to work. Ideally annotations would be attributes to the bar, this way you could separate them. You guys are way too creative when it comes to annotations. You need more rigor if you want to extract the data. ymg Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 18, 2014 Author Share Posted February 18, 2014 thanks brother.. How u got a manuel lisp ? for example: I select 2ƒ14 then ı select lenght. and lisp write excel one under the other. for example 2f14 L=120 I want only this. which rebar I select it will write excel cel A,1 and which rebar lenght I select it write excel cel B,1 3f14 L=250 and other rebar wroten by lisp excel:A,1 and lenght B,2 but its manualy Quote Link to comment Share on other sites More sharing options...
ymg3 Posted February 18, 2014 Share Posted February 18, 2014 there u Go! (defun c:rep2 (/ ent1 ent2 fh fname) (setq fname (strcat (getvar "dwgprefix") (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4 )) ".csv") fh (open fname "a") ) (while (setq en1 (car (entsel "\nSelect a bar: "))) (setq en2 (car (entsel "\nSelect it's length: "))) (write-line (strcat (cdr (assoc 1 (entget en1))) ", " (cdr (assoc 1 (entget en2)))) fh) ) (princ (strcat "\nFile: " fname " has been created.")) (close fh) ) Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 18, 2014 Author Share Posted February 18, 2014 very very thanks ymg:)) u are a perfect man:) Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 20, 2014 Author Share Posted February 20, 2014 Im sorry ymg.Im a problem for u I know:( But which I select bar type or lenght, its color will change. I dont know which was I selected:(( Quote Link to comment Share on other sites More sharing options...
ymg3 Posted February 20, 2014 Share Posted February 20, 2014 This will creates a layer named "SELECTED" with color Yellow. As you select entity rhey will be put on that layer. (defun c:rep2 (/ ent1 ent2 fh fname) (setq fname (strcat (getvar "dwgprefix") (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4 )) ".csv") fh (open fname "a") ) (command "_-LAYER" "_M" "SELECTED" "_C" 2 "" "") (while (setq en1 (car (entsel "\nSelect a bar: "))) (setq ent1 (entget en1) ent1 (subst (cons 8 "SELECTED") (assoc 8 ent1) ent1) ) (entmod ent1) (setq en2 (car (entsel "\nSelect it's length: "))) (setq ent2 (entget en2) ent2 (subst (cons 8 "SELECTED") (assoc 8 ent2) ent2) ) (entmod ent2) (write-line (strcat (cdr (assoc 1 ent1)) ", " (cdr (assoc 1 ent2))) fh) ) (princ (strcat "\nFile: " fname " has been created.")) (close fh) ) Quote Link to comment Share on other sites More sharing options...
ekolman2003 Posted February 20, 2014 Author Share Posted February 20, 2014 thanks very very much Quote Link to comment Share on other sites More sharing options...
kelleci Posted January 5, 2015 Share Posted January 5, 2015 Hi I have a smilar problem about steel quantity. I replaced ƒ#* text with %%O%%C%%O code but it didnt work in my case. Here is my project and modified lsp file.Any help i will grateful for this. Best regards. TEST.lsp Project.dwg Quote Link to comment Share on other sites More sharing options...
ymg3 Posted January 5, 2015 Share Posted January 5, 2015 kelleci, Try: (setq ss (ssget "_X" '((0 . "TEXT") (1 . "*%%O%%C%%O*")))) Quote Link to comment Share on other sites More sharing options...
kelleci Posted January 6, 2015 Share Posted January 6, 2015 Hi Thanks for the help and interest.But it seems cant find that char.It gives only 3 outputs in excel file. Here is the code: (defun c:test (/ dir dist en en2 ent ent2 fh fname f1 f2 foundl i j mn mx nomatch p1 p2 searchlen ss ss2) ;; File is opened in Append Mode ; (setq fname (strcat (getvar "dwgprefix") (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 4 )) ".csv") fh (open fname "a")) (setq scrsize (getvar 'SCREENSIZE) ratio (/ (car scrsize) (cadr scrsize)) searchlen (* (getvar 'VIEWSIZE) ratio) ; Length of Selection Fence ; nomatch 0 ; Number of Items with no matched length ; ) ;; Selecting All Text with Character ASCII 131 ; (if (setq ss (ssget "_X" '((0 . "TEXT") (1 . "*%%O%%C%%O*")))) (progn (repeat (setq i (sslength ss)) (setq en (ssname ss (setq i (1- i))) ent (entget en) dir (cdr (assoc 50 ent)) ) (vla-getboundingbox (vlax-ename->vla-object en) 'mn 'mx) (setq p1 (vlax-safearray->list mn) p2 (vlax-safearray->list mx) ) ;; First point of fence is midpoint of Bar Description. ; (setq f1 (list (/ (+ (car p2) (car p1)) 2.) (/ (+ (cadr p2) (cadr p1)) 2.)) f2 (polar f1 dir searchlen) ) (if (setq ss2 (ssget "_F" (list f1 f2) '((0 . "TEXT") (1 . "L=#*")))) (progn (setq foundl nil) (repeat (setq j (sslength ss2)) (setq en2 (ssname ss2 (setq j (1- j))) ent2 (entget en2) dist (distance f1 (cdr (assoc 10 ent2))) foundl (cons (list dist (cdr (assoc 1 ent2))) foundl) ) (setq foundl (vl-sort foundl (function (lambda (a b) (< (car a) (car b)))))) (write-line (strcat (cdr (assoc 1 ent)) ", " (cadr (car foundl))) fh) ) ) ;; If we did nod not find put a rectangle around the entity. ; (progn (vl-cmdf "_RECTANGLE" p1 p2) (setq nomatch (1+ nomatch)) ) ) ) ) ) (princ (strcat "File: " fname " has been created.")) (close fh) (if (> nomatch 0) (alert (strcat (itoa nomatch) " Bars could not be matched."))) (princ) ) Am i doing something wrong? Best regards. Quote Link to comment Share on other sites More sharing options...
