cadmariner Posted February 3, 2014 Posted February 3, 2014 I have a file that was probably created in a different type of software and exported to Autocad, I want to get rid of these squares without exploding the Blocks. see attached pic. Quote
cadmariner Posted February 3, 2014 Author Posted February 3, 2014 Nope. Tried that. These squares disappear when I explode them. Here is the file. 2009727E-102.dwg Quote
rkent Posted February 3, 2014 Posted February 3, 2014 Use the XCLIP command, select them all and Delete them. Quote
cadmariner Posted February 3, 2014 Author Posted February 3, 2014 That is the solution. Thanks for your help. I did not know that the XCLIP command would work on blocks too. Quote
