knafziger Posted February 3, 2014 Posted February 3, 2014 Hi There, I seem to have lost the ability to use short-form commands in the command prompt. I was able to do it, and not I can't. I don't know what changed. For instance.... I can type in 'LINE' and the line command will initiate; However, I cannot initiate the line command by typing in 'L'. I have tried to change it through the CUI with no luck. Other commands like, move and copy are effected too. Please help! Quote
rkmcswain Posted February 3, 2014 Posted February 3, 2014 (edited) Take a look at the image linked below. I think LT will have this same command in the Ribbon. Try this and if it's there, it should open the PGP file in Notepad. This is the file that defines many one or two button shortcuts. http://www.cadlinecommunity.co.uk/Blogs/DanielTaylor/25_March_daniel_taylor_blog_image_1.png Edited February 3, 2014 by rkmcswain add more detail Quote
knafziger Posted February 3, 2014 Author Posted February 3, 2014 Thank you... I did find the 'Edit Aliases' however when I click on it, it says 'File acadlt.pgp could not be found'. I'm not sure where to point my 'Support File Search Path' to find it. Quote
rkmcswain Posted February 3, 2014 Posted February 3, 2014 knafziger said: Thank you... I did find the 'Edit Aliases' however when I click on it, it says 'File acadlt.pgp could not be found'. I'm not sure where to point my 'Support File Search Path' to find it. Good, that explains why your shortcuts are not working. The easiest way to fix this would be to run a REPAIR on your AutoCAD LT install. If the problem is just that your support file search paths are messed up, then you may just need to reset your profile (Options > Profiles > Reset) Quote
knafziger Posted February 3, 2014 Author Posted February 3, 2014 Thank you... everything works now. Much appreciated! Quote
